[Qgis-developer] different proxy-types
Stephan Holl
stephan.holl at intevation.de
Tue May 5 11:23:55 EDT 2009
Hello Andreas,
"Andreas Neumann" <a.neumann at carto.net>, [20090505 - 17:10:38]
> Hi Stephan,
> As far as I know, the different types you listed are just the types
> that qt offers as proxy types. In most cases, the "Default Proxy" or
> the "HttpProxy" should work fine. I some special cases, other proxies
> may have to be used. I think it is very specific to the proxy that is
> in use and sometimes you need some "trial and error" ...
> Maybe it would be useful to link from the manual to here:
> http://doc.trolltech.com/4.5/qnetworkproxy.html#ProxyType-enum
> In my case I am using the "HttpProxy" which works fine with Squid.
Thanks for the useful link; I will work from that point.
Thanks
Stephan
> On Tue, May 5, 2009 4:32 pm, Stephan Holl wrote:
> > Dear devs,
> > I would like to update the manual for the 1.1 release and need some
> information about $subject.
> > Could someone (probably the implementer) please fill the keywords
> > with
> some more content, so that we can describe it in a separate section
> within the manual?
> > * Default Proxy:
> > * Socks5Proxy:
> > * HttpProxy:
> > * HttpCachingProxy:
> > * FtpCachingProxy:
> > TIA
> > Best
> > Stephan
> > Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508
> > 3663
> Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B
> 18998 Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr.
> Jan-Oliver Wagner _______________________________________________
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090505/23cf6e6a/signature.bin
