[Qgis-developer] Slow project opening
Tim Sutton
lists at linfiniti.com
Tue May 5 17:43:57 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Manuel Massing wrote:
> Hi Craig,
> in my experience slow loading of project files is often due to
> thumbnail creation, which requires creating a downsampled
> version of the file. This may be very inefficient if the input file
> does not support overviews.
> You could try adding overviews for your input rasters using the gdal
> utility "gdaladdo".
Could I suggest you use the gdalbuildvrt tool to create a single virtual
raster dataset. Its much more efficient and means you only need to add a
single layer to the legend which is much easier to deal with visually.
You need gdal 1.6 with python support for the tool I believe.
Regards
Tim
> cheers,
> Manuel
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkoAsvAACgkQqk07qZdiYjfBPACggTu1aqk0rjtMs6r4rhrbcHgY
mzcAn2RT+5y+X4B4pJEMRmDdGMn+1tEJ
=RyUH
-----END PGP SIGNATURE-----
