[Qgis-developer] QGIS-Trunk Python-Path error?
Martin Dobias wonder.sk at gmail.com
Thu May 14 07:19:16 EDT 2009
On Wed, May 13, 2009 at 2:17 PM, Düster Horst <Horst.Duester at bd.so.ch> wrote:
> I just installed QGIS-trunk -r10777 from svn. With ccmake I made the following settings:
> BINDINGS_GLOBAL_INSTALL: off
> CMAKE_INSTALL_PREFIX: /usr/local/qgis_devel
> WITH_BINDINGS: on
> Compilation and installation process works fine. But when I start QGIS with
> /usr/local/qgis_devel/bin/qgis
> I get the following error message:
> ImportError: /usr/local/qgis/share/qgis/python/qgis/core.so:
> undefined symbol: _ZN16QgsDataSourceURI13setDataSourceERK7QStringS2_S2_S2_
> I seems that QGIS points to the wrong directory for connecting the python bindings. The error path is  the path to a second QGIS 1.0.1 installation.
> I remember, that this error occours when two independent qgis installations exists and BINDINGS_GLOBAL_INSTALL is set ton on.
> What is the mistake??
I'm not sure what's happening here. Have you done the install from a
new build directory?
I mean if pyqgis links to a different installation, there might be
some rests of the old configuration that were somehow picked up by the
bindings. If that's the case, I would recommend to do a clean build.
Bye
Martin
