[Qgis-developer] OSGeo4W: Qgis 1.0.1
Jürgen E. Fischer
jef at norbit.de
Fri May 22 10:14:45 EDT 2009
Hi Stephan,
On Fri, 22. May 2009 at 13:51:22 +0200, Stephan Holl wrote:
> > When a non file based layer qgis tries to load the defaults from the
> > above file, a file named like the project, but ending on .qmldb or
> > the qgis.qmldb in the qgis resources directory.
> > There's no UI to transfer the settings from the user's qgis.qmldb
> > into the project or resources database.
> Ok, is is sufficient to create a qgis.qmldb and copy it to the global
> ressources-folder? Would it be picked up as the fallback (for a global
> installation)?
Yes.
BTW the uri of the data source is used as key to the qmldb. That means that if
you add a layer from the same table, but with a changed parameters (ie.
different credentials, sslmode or anything else) the defaults won't be found.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
