[Qgis-developer] OSGeo4W: Qgis 1.0.1
Stephan Holl
stephan.holl at intevation.de
Fri May 22 07:51:22 EDT 2009
Hallo Jürgen,
Jürgen E. Fischer <jef at norbit.de>, [20090522 - 12:07:11]
> Hi Stephan,
> On Wed, 20. May 2009 at 08:01:52 +0200, Stephan Holl wrote:
> > * Using *.qml-files with saved styles work perfectly with
> > shapefiles. If I place the saved *.qml-file with the identical name
> > as the shapefile it gets picked up as soon as I load the shapefile.
> > Where do I need to put the *.qml-file for a PostGIS-layer?
> QML files are only for file based layers. The defaults for other
> layers are stored to the qgis.qmldb SQLite database in the .qgis
> directory (%USERPROFILE%\.qgis on Windows and ~/.qgis on *x).
Ah, thanks for the clarifications.
> When a non file based layer qgis tries to load the defaults from the
> above file, a file named like the project, but ending on .qmldb or
> the qgis.qmldb in the qgis resources directory.
ok, thank you very much.
> There's no UI to transfer the settings from the user's qgis.qmldb
> into the project or resources database.
Ok, is is sufficient to create a qgis.qmldb and copy it to the global
ressources-folder? Would it be picked up as the fallback (for a global
installation)?
Best regards
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090522/22c4e5d6/signature.bin
