[Qgis-developer] Re: qgis binary compiled with new gdal-mrsid -
1.6.1-2 ?
Jürgen E. Fischer
jef at norbit.de
Fri May 29 13:12:05 EDT 2009
Hi Agus,
On Fri, 29. May 2009 at 11:50:17 +0200, Agustin Lobo wrote:
> Jef,
Please don't call me by my initials. I'm Jürgen. ;)
> Are you planning to build the QGIS binaries for ubuntu using the new
> gdal-mrsid - 1.6.1-2 library ?
I've added a new ppa that depends on the ubuntugis ppa and copied the source
packages across. The QGIS available there were build with GDAL 1.6 from
ubuntugis and should therefore work with MrSid files, if you have the
appropriated GDAL plugins installed:
deb http://ppa.launchpad.net/jef-norbit/qgis-unstable-ubuntugis-jef/ubuntu jaunty main
If you can verify that they are working, we should probably copy QGIS into the
ubuntugis ppa (for which I would need to be reactivated) - or into a new qgis
ppa.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
