[Qgis-developer] Re: qgis binary compiled with new gdal-mrsid -
1.6.1-2 ?
Agustin Lobo
alobolistas at gmail.com
Fri May 29 13:37:33 EDT 2009
Jürgen,
I'm trying but have a problem with the key. I do:
alobo at alobo-laptop:~$ wget http://www.array.org/ubuntu/array-apt-key.asc
--19:32:09-- http://www.array.org/ubuntu/array-apt-key.asc
=> `array-apt-key.asc.1'
Resolving www.array.org... 72.167.46.68
Connecting to www.array.org|72.167.46.68|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1,795 (1.8K) [text/plain]
100%[===================================================================================================>]
1,795 --.--K/s
19:32:11 (5.87 MB/s) - `array-apt-key.asc.1' saved [1795/1795]
alobo at alobo-laptop:~$ gpg --keyserver keyserver.ubuntu.com --recv-keys
B26A1B1A389C663C
gpg: requesting key 389C663C from hkp server keyserver.ubuntu.com
gpg: key 389C663C: "Launchpad PPA for Jürgen E. Fischer" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
but then:
alobo at alobo-laptop:~$ gpg --armor B26A1B1A389C663C | sudo apt-key add -
gpg: can't open `B26A1B1A389C663C'
gpg: no valid OpenPGP data found.
am I doing something wrong or is there a problem with the key?
The problem is that I get the "Partial upgrade" message, which always
implies more problems afterwards.
A.L. ;)
Jürgen E. Fischer wrote:
> Hi Agus,
> On Fri, 29. May 2009 at 11:50:17 +0200, Agustin Lobo wrote:
>> Jef,
> Please don't call me by my initials. I'm Jürgen. ;)
>> Are you planning to build the QGIS binaries for ubuntu using the new
>> gdal-mrsid - 1.6.1-2 library ?
> I've added a new ppa that depends on the ubuntugis ppa and copied the source
> packages across. The QGIS available there were build with GDAL 1.6 from
> ubuntugis and should therefore work with MrSid files, if you have the
> appropriated GDAL plugins installed:
> deb http://ppa.launchpad.net/jef-norbit/qgis-unstable-ubuntugis-jef/ubuntu jaunty main
> If you can verify that they are working, we should probably copy QGIS into the
> ubuntugis ppa (for which I would need to be reactivated) - or into a new qgis
> ppa.
> Jürgen
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090529/386292e7/alobolistas.vcf
