[Qgis-developer] Installing the Qgis 1.0.2 package for Ubuntu
Joseph Reeves
iknowjoseph at gmail.com
Tue Nov 3 07:19:49 EST 2009
Hi Henri,
I thin you were right with your original email - Karmic releases don't
seem to be there.
PPAs are "Private Package Archives" - basically software that isn't in
the main Ubuntu repositories, Usually this represents development
releases, or software otherwise not suited to being distributed with
Ubuntu.
In Ubuntu you can click System - Administration - Software Sources
Enter your password when prompted
Click the Other Software tab and hit the Add... button.
Paste in:
ppa:qgis/stable
And click Add Source. Your PC will then download a list of software
available to you - this now includes QGIS. From the terminal you could
run:
sudo apt-get install qgis
or you could look for the app in the new Ubuntu Software Centre.
However... When I did the above my souftware sources refreshed and I was told:
Failed to fetch
http://ppa.launchpad.net/qgis/stable/ubuntu/dists/karmic/main/binary-i386/Packages.gz
404 Not Found
Looking at the server it seems that karmic is missing:
So yes, back to your original question, can the 9.04 sources be used
instead? Sorry, I don't know the answer to that one.
Cheers, Joseph
2009/11/3 Henri De Feraudy <feraudyh at yahoo.com>:
> Thankyou Joseph
> I didnt know what PPA's and all that were until an hour ago, and installed
> Ubuntu this morning out of desperation.
> Henri
> --- On Tue, 11/3/09, Joseph Reeves <iknowjoseph at gmail.com> wrote:
>> From: Joseph Reeves <iknowjoseph at gmail.com>
>> Subject: Re: [Qgis-developer] Installing the Qgis 1.0.2 package for Ubuntu
>> To: "Henri De Feraudy" <feraudyh at yahoo.com>
>> Cc: qgis-developer at lists.osgeo.org
>> Date: Tuesday, November 3, 2009, 1:02 PM
>> 9.10 is there as the default; you'll
>> see it reads:
>> "You can update your system with unsupported packages from
>> this
>> untrusted PPA by adding ppa:qgis/stable to your system's
>> Software
>> Sources. "
>> The it says:
>> "Not using Ubuntu 9.10 (karmic)?"
>> So click there if you're not using Karmic, otherwise, read
>> the first sentence.
>> That's how I understand it at least...
>> Cheers, Joseph
>> > Hello,
>> > Since I cant get the first tutorial application
>> (timtut1.exe) to work for
>> > Windows I'm trying to see if I can make it work on
>> Ubuntu.
>> > So I installed Ubuntu Karmic Koala last night. It's
>> been out since the 29th of October, if I remember rightly.
>> > When I go to look for the Ubuntu package on
>> > https://launchpad.net/~qgis/+archive/stable
>> > I see that Karmic Koala (the latest Ubuntu) is not yet
>> taken into account.
>> > Can I use the Jaunty package?
>> > Henri
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
