[Qgis-developer] Installing the Qgis 1.0.2 package for Ubuntu
Henri De Feraudy
feraudyh at yahoo.com
Tue Nov 3 07:20:52 EST 2009
Thankyou,
I added ppa:qgis/stable to the second page of the Synaptic Software source dialog box and it was automagically rewritten into
http://ppa.launchpad.net/qgis/stable/ubuntu karmic main
(I dont know how, I only installed Ubuntu this morning)
then when I pressed on the Synaptic main window's reload button
things went smoothly for a while but after loading about 54 files
I got an error message saying that not all index files could be loaded.
regards
Henri
--- On Tue, 11/3/09, Joseph Reeves <iknowjoseph at gmail.com> wrote:
> From: Joseph Reeves <iknowjoseph at gmail.com>
> Subject: Re: [Qgis-developer] Installing the Qgis 1.0.2 package for Ubuntu
> To: "Henri De Feraudy" <feraudyh at yahoo.com>
> Cc: qgis-developer at lists.osgeo.org
> Date: Tuesday, November 3, 2009, 1:02 PM
> 9.10 is there as the default; you'll
> see it reads:
> "You can update your system with unsupported packages from
> this
> untrusted PPA by adding ppa:qgis/stable to your system's
> Software
> Sources. "
> The it says:
> "Not using Ubuntu 9.10 (karmic)?"
> So click there if you're not using Karmic, otherwise, read
> the first sentence.
> That's how I understand it at least...
> Cheers, Joseph
> 2009/11/3 Henri De Feraudy <feraudyh at yahoo.com>:
> > Hello,
> > Since I cant get the first tutorial application
> (timtut1.exe) to work for
> > Windows I'm trying to see if I can make it work on
> Ubuntu.
> > So I installed Ubuntu Karmic Koala last night. It's
> been out since the 29th of October, if I remember rightly.
> > When I go to look for the Ubuntu package on
> > https://launchpad.net/~qgis/+archive/stable
> > I see that Karmic Koala (the latest Ubuntu) is not yet
> taken into account.
> > Can I use the Jaunty package?
> > Henri
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
