[Qgis-developer] fTools projection error?
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Nov 11 06:05:51 EST 2009
On Wed, 2009-11-11 at 10:23 +0100, Paolo Cavallini wrote:
> Hi all.
> When defining a projection for a file that misses it, fTools writes a file
> named "filename.shp|layerid=0.prj" instead of "filename.prj": can you
> confirm?
I tested qgis 1.3 and trunk under Ubuntu linux and I confirm that with
trunk it writes the wrong filename, while with 1.3 is ok.
cheers
-- Giovanni --
