[Qgis-developer] fTools projection error?
Carson Farmer carson.farmer at gmail.com
Wed Nov 11 07:30:21 EST 2009
Yes I can also confirm this, it must be something that was changed in
trunk... I will try to figure out why and get to the bottom of it...
Carson
On Wed, Nov 11, 2009 at 11:05 AM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
> On Wed, 2009-11-11 at 10:23 +0100, Paolo Cavallini wrote:
>> Hi all.
>> When defining a projection for a file that misses it, fTools writes a file
>> named "filename.shp|layerid=0.prj" instead of "filename.prj": can you
>> confirm?
> I tested qgis 1.3 and trunk under Ubuntu linux and I confirm that with
> trunk it writes the wrong filename, while with 1.3 is ok.
> cheers
> -- Giovanni --
> Qgis-developer mailing list
Carson Farmer
National Centre for Geocomputation
John Hume Building,
National University of Ireland, Maynooth,
Maynooth,
Co. Kildare,
Ireland.
www.carsonfarmer.com
