[Qgis-developer] Crash with new Label-Plugin
Andreas Neumann
a.neumann at carto.net
Thu Nov 19 05:13:50 EST 2009
I am playing around with the new label engine from Martin. It seems to be
very promising. It works fine for linear features.
However, whenever I try to label an area feature, QGIS crashes, both on
the Windows nightly build, but also with the SVN version on Linux Ubuntu,
64bit. QGIS immediately crashes after I hit the OK button.
Does labeling of area features work for other people?
I get the following message on the console:
Warning: Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of
'pal::PalException::FeatureExists*'
Aborted
If this also fails for other people I will do a bug report.
Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
Andreas Neumann
