[Qgis-developer] Crash with new Label-Plugin
Martin Dobias wonder.sk at gmail.com
Thu Nov 19 06:09:14 EST 2009
Hi Andreas
please send me the data you're using so I can investigate the issue...
Martin
On Thu, Nov 19, 2009 at 11:13 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> I am playing around with the new label engine from Martin. It seems to be
> very promising. It works fine for linear features.
> However, whenever I try to label an area feature, QGIS crashes, both on
> the Windows nightly build, but also with the SVN version on Linux Ubuntu,
> 64bit. QGIS immediately crashes after I hit the OK button.
> Does labeling of area features work for other people?
> I get the following message on the console:
> Warning: Qt has caught an exception thrown from an event handler. Throwing
> exceptions from an event handler is not supported in Qt. You must
> reimplement QApplication::notify() and catch all exceptions there.
> terminate called after throwing an instance of
> 'pal::PalException::FeatureExists*'
> Aborted
> If this also fails for other people I will do a bug report.
> Andreas
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
> Andreas Neumann
> Qgis-developer mailing list
