[Qgis-developer] 2 versions on the same machine
Alex Mandel tech_dev at wildintellect.com
Wed Nov 25 02:09:23 EST 2009
For some reason if I install 1.3 from packages and then go and build
trunk with a prefix of /home/myuser/apps/, right after make install my
1.3 version starts getting the following error. Note that a simple make
uninstall takes the system back to the way it was no python errors on
1.3 start. To me it seems like after the trunk install 1.3 is somehow
reading something it shouldn't be, but what might that be.
It's not really a bug but I would love to be able to test things in
trunk as they come while maintaining a working version for work.
Ubuntu 9.04, Ubuntugis repos
Thanks - Alex
Couldn't load QGIS utils.
Python support will be disabled.
  File "", line 1, in
ImportError: No module named utils
Python version:
2.6.2 (release26-maint, Apr 19 2009, 02:11:59)
[GCC 4.3.3]
Python path:
['/python', '/home/madadh/.qgis//python/plugins', '/python/plugins',
'/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
'/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
'/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/Numeric',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10',
'/var/lib/python-support/python2.6',
'/usr/lib/python2.6/dist-packages/gtk-2.0',
'/var/lib/python-support/python2.6/gtk-2.0',
'/usr/lib/python2.6/dist-packages/wx-2.6-gtk2-unicode',
'/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
'/usr/local/lib/python2.6/dist-packages']
