AW: [Qgis-developer] thanks for field calculator
Marco Hugentobler
marco at hugis.net
Thu Oct 1 07:23:13 EDT 2009
Hi Cedric
> Is it possible to 'overwrite' an existing field? For them moment it always
> gives you a new field, is this correct?
Yes, atm it always makes a new field. It would also be possible to adapt the
field calculator to overwrite existing fields without much effort (mainly changes
in the GUI).
>Is there a chance to have a
> possiblity to only calculate selected rows and leave the other rows as they
> are?
This is a usefull suggestion too (mainly in connection with the first one I
guess).
Thanks for your input,
Marco
Am Donnerstag, 1. Oktober 2009 13.01:36 schrieb Möri Cedric:
> Hi Marco and all
> The field calculator is a great thing to have. Thanks a lot.
> I've two little questions about it:
> gives you a new field, is this correct? Is there a chance to have a
> are?
> Thanks again for the good work.
> regards
> Cédric
> mit freundlichen Grüssen
> Cédric Möri
> GIS-Informatiker
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> Telefon: +41 (0)32 627 24 75
> Telefax: +41 (0)32 627 22 14
> mailto:cedric.moeri at bd.so.ch
> http://www.agi.so.ch
> ----- Originalnachricht -----
> Von: Marco Hugentobler <marco at hugis.net>
> Gesendet: Mit, 30.9.2009 13:35
> An: qgis-developer at lists.osgeo.org ; giovanni.manghi at faunalia.pt
> Betreff: Re: [Qgis-developer] thanks for field calculator
> Hi Giovanni
> Yes, there is room for more operators. The list in the ticket seems to be
> usefull to me. I just like to wait for Martins opinion before adding more
> operators, since he knows the search string parser code best.
> I'm closing the ticket if there are no objections.
> Regards,
> Marco
> Am Mittwoch, 30. September 2009 13.14:58 schrieb Giovanni Manghi:
> > I would like to thank Marco for adding the field calculator, it was much
> > needed (as many other features added by other devs in the last months!).
> > I would like also to know it then we can close
> > https://trac.osgeo.org/qgis/ticket/243
> > and if there is room to add more operators to the calculators.
> > cheers
> > -- Giovanni --
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
