[Qgis-developer] thanks for field calculator
    Darren Cope
    darrencope at gmail.com
    Mon Oct  5 12:23:20 EDT 2009
Wow!  Great news!  This is a much needed feature in QGIS--well done!
A couple of comments:
1)  The tool is buried under a lot of menus.  I think the ideal place for it
would be directly on the Attribute Table beside the "Toggle Editing" button.
2)  It would be great to have a feature to calculate x,y, area, and length
(I think I saw this mentioned somewhere already, but I'm adding a vote)
without using fTools (and exporting to a new file)
3)  Ideally, a way to calculate a unique ID for a table (e.g.
auto-incrementing sequential numbers).  One way of doing this (implemented
in Kosmo GIS) is to show the 'invisible' ID associated with the shapefile
(e.g. the 'row number' that shows up in the attribute table) and make it
available for calculations.
Cheers,
Darren
Marco Hugentobler wrote:
> Hi Giovanni
> Yes, there is room for more operators. The list in the ticket seems to be
> usefull to me. I just like to wait for Martins opinion before adding more
> operators, since he knows the search string parser code best.
> I'm closing the ticket if there are no objections.
> Regards,
> Marco
> Am Mittwoch, 30. September 2009 13.14:58 schrieb Giovanni Manghi:
>> I would like to thank Marco for adding the field calculator, it was much
>> needed (as many other features added by other devs in the last months!).
>> I would like also to know it then we can close
>> https://trac.osgeo.org/qgis/ticket/243
>> and if there is room to add more operators to the calculators.
>> cheers
>> -- Giovanni --
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> HUGIS - GIS programming and consulting
> Webereistrasse 66
> CH-8134 Adliswil
> marco at hugis.net
> http://homepage.hispeed.ch/hugis
View this message in context: http://n2.nabble.com/thanks-for-field-calculator-tp3742029p3769924.html
Sent from the qgis-developer mailing list archive at Nabble.com.
