[Qgis-developer] Plugin specific maplayers
Mathias Walker
mwa at sourcepole.ch
Tue Oct 6 05:05:13 EDT 2009
Hello
At the moment our mapfile plugin only works when adding a mapfile layer using
the plugin dialog. This is done by creating a temporary image and adding it
as a raster layer. This image is then rerendered on every change of the map
canvas extents.
But this layer will not be restored when saving it in a project, as the
temporary image no longer exists. Also the plugin can not detect which layer
belonged to it or what parameters to use.
To solve these issues it would be nice to have a new plugin specific maplayer
type.
Desired features:
- attach layer to corresponding plugin when loading a project
- get plugin specific parameters to recreate the layer
- handle layers with missing plugins
- save plugin specific parameters when saving a project
- detach from plugin when removing the layer
- create and add layer using the plugin
- get layer draw events for custom rendering based on current extents and
image size
- customizable layer properties dialog
Several of these features can be solved with workarounds using the QGIS API.
But especially the problem of restoring a layer when loading a project is
still unsolved.
What would be the best approach to integrate plugin specific maplayers into
QGIS?
Some ideas:
- add a new class QgsPluginRasterDataProvider : QgsRasterDataProvider, though
the QgsRasterDataProvider interface is rather WMS specific
- or add a new class QgsPluginLayer : QgsMapLayer and LayerType::PluginLayer
which would cause a lot of adjustments all over the place
Best regards
Mathias Walker
Sourcepole - Linux & Open Source Solutions
Elestastr. 18 7310 Bad Ragaz Switzerland
Tel: 081 330 77 11 Fax: 081 330 77 12
mwa at sourcepole.ch http://www.sourcepole.ch
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091006/cf771770/attachment.bin
