[Qgis-developer] py2exe error - Key Error - CLSIDToCLASS,
EnsureDispatch
Bishwarup Banerjee
bishwarup.banerjee at gmail.com
Thu Oct 8 06:52:45 EDT 2009
Dear German,
Thank you very much for your response. I am able to include sip files now.
But I am stuck in one another problem now.
In my application, there is a win32 application (I am calling MS Word from
inside python)
When I run my python file, everything works fine. But when i run my exe I
get the following error:
File "win32com\client\gencache.pyc", line 540, in EnsureDispatch
File "win32com\client\CLSIDToClass.pyc", line 50, in GetClass
KeyError: '{00020970-0000-0000-C000-000000000046}'
I dont know how to overcome this error. I tried in google, and only found
one solution, that also didnot worked for me.
I am having MSOFFICE 2003 and MSOFFICE2007 both in my system.
I am using python2.5
Thank you very much in advance.
With Warm Regards,
Bishwarup
2009/10/7 Germán Carrillo <carrillo.german at gmail.com>
> Hi Bishwarup.
> You must put the following line to the setup options of py2exe:
> "includes": ['sip'],
> This will include the sip module to the generated dir.
> Regards.
> Germán.
> 2009/10/7 Bishwarup Banerjee <bishwarup.banerjee at gmail.com>
>> Dear All,
>> I was trying to convert my python code to exe. Everything went on fine.
>> But when I tried to execute the exe, this is giving the following error.
>> Traceback (most recent call last):
>> File "Final.py", line 1, in <module>
>> File "PyQt4\QtCore.pyc", line 12, in <module>
>> File "PyQt4\QtCore.pyc", line 10, in __load
>> ImportError: No module named sip
>> Any idea why it is happening?
>> Thank you in advance.
>> Bishwarup
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091008/596f13d6/attachment.html
