[Qgis-developer] QgsMapLayerRegistry [partially solved]
Michele Mammini
mamminim at yahoo.it
Thu Oct 8 10:20:03 EDT 2009
Like in the subject I solved a part of my problem.
The correct code to remove the layer from QGis is:
currentLayer = self.iface.activeLayer()
RegIns = QgsMapLayerRegistry.instance()
RegIns.removeMapLayer(currentLayer.getLayerID())
but it working if i use it in Python Console, while QGis crash if I
use it in my plugin code
Dear All,
i have a problem with QgsMapLayerRegistry class when i try to remove
a Layer from QGis.
i use this two code line:
RegIns.removeMapLayer(layerName)
where layerName is set with this command line: layerName =
self.iface.activeLayer().name()
Do someone know how to solve it?
Thank you Michele.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091008/ba6d4d16/attachment.html
