[Qgis-developer] QgsMapLayerRegistry [partially solved]
Germán Carrillo
carrillo.german at gmail.com
Thu Oct 8 12:21:01 EDT 2009
Hi Michele.
I guess you must update the canvas layer set after remove a layer from
QgsMapLayerRegistry.
Germán Carrillo
2009/10/8 Michele Mammini <mamminim at yahoo.it>
> Like in the subject I solved a part of my problem.
> The correct code to remove the layer from QGis is:
> currentLayer = *self*.iface.activeLayer()
> RegIns = QgsMapLayerRegistry.instance()
> RegIns.removeMapLayer(currentLayer.getLayerID())
> but it working if i use it in Python Console, while QGis crash if I use it
> in my plugin code
> Dear All,
> i have a problem with QgsMapLayerRegistry class when i try to remove a
> Layer from QGis.
> i use this two code line:
> RegIns.removeMapLayer(layerName)
> where layerName is set with this command line: layerName = *self*
> .iface.activeLayer().name()
> Do someone know how to solve it?
> Thank you Michele.
> Qgis-developer mailing list
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091008/cb70b9f4/attachment.html
