[Qgis-developer] Re: SVG export
Standaert Arnout
arnout.standaert at vito.be
Fri Oct 9 05:28:40 EDT 2009
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> Sent: vrijdag 9 oktober 2009 11:15
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Re: SVG export
> In my opinion, the svg composer export is not that bad. There
> is one problem
> with clipping (Qt does not support that) and one with scaling
> (probably fixable
> in the composer export).
Another problem I frequently stumble upon is point markers: in the SVG output, these are usually shown as bitmap symbols instead of true SVG. Same goes for the PDF output, point markers are also bitmapped in there.
Outputting layered SVG corresponding to map layers would also be *very* nice. I once started writing a plugin to do this, but never got very far. In any case, it would very much facilitate the Qgis -> Inkscape/Illustrator workflow!
Regards,
Arnout
Uniting expertise from different fields of technology in a pleasant and stimulating environment enhances innovation and the development of novel methods for sustainable production.
Have a look at the international congress 'Innovation for Sustainable Production 2010'
April, 18-21, 2010 - Bruges (Belgium)
http://www.i-sup2010.org
This e-mail, any attachments and the information it contains are confidential and meant only for the use of the addressee(s) only. Access to this e-mail by anyone other than the addressee(s) is unauthorized. If you are not the intended addressee (or responsible for delivery of the message to such person), you may not use, copy, distribute or deliver to anyone this message (or any part of its contents) or take any action in reliance on it. In such case, you should destroy this message and notify the sender immediately. If you have received this e-mail in error, please notify us immediately by e-mail or telephone and delete the e-mail from any computer.
All reasonable precautions have been taken to ensure no viruses are present in this e-mail and its attachments. As our company cannot accept responsibility for any loss or damage arising from the use of this e-mail or attachments we recommend that you subject these to your virus checking procedures prior to use.
