[Qgis-developer] Windows all in one installer under Vista
Tim Sutton
lists at linfiniti.com
Mon Oct 12 13:14:36 EDT 2009
Hi
Ah ok thanks for the tip - I will try that next time!
Regards
Tim
------Original Message------
To: Mailing Lists
Cc: QGIS Developer
ReplyTo: giovanni.manghi at gmail.com
Subject: Re: [Qgis-developer] Windows all in one installer under Vista
Sent: Oct 12, 2009 6:58 PM
I Tim,
you have to right click on the installer file and in the properties
select to allow install the program as "administrator", or something
like that... I also try to avoid touch Vista.
cheers
-- Giovanni --
On Mon, 2009-10-12 at 18:55 +0200, Mailing Lists wrote:
> Hi All
> I had a (painful) opportunity to use Vista for a few hours the other
> day. I tried to install my QGIS windows 1.3.0-3 build on it. Although
> it seems to install fine, it doesnt show up anywhere in the menus or
> in the filesystem that I can see. Does anyone have any knowledge on
> Vista? Did I forget to do some magic incantation?
> Regards
Sent from my mobile phone.
