[Qgis-developer] Windows all in one installer under Vista
Martin Dobias
wonder.sk at gmail.com
Thu Oct 15 12:18:43 EDT 2009
I've came across this issue too - installer silently ignores errors
due missing permissions when copying files. Since people are slowly
upgrading to vista and win7, the installer probably should get fixed
to avoid further confusion...
Martin
On Mon, Oct 12, 2009 at 6:58 PM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
> I Tim,
> you have to right click on the installer file and in the properties
> select to allow install the program as "administrator", or something
> like that... I also try to avoid touch Vista.
> cheers
> -- Giovanni --
> On Mon, 2009-10-12 at 18:55 +0200, Mailing Lists wrote:
>> Hi All
>> I had a (painful) opportunity to use Vista for a few hours the other
>> day. I tried to install my QGIS windows 1.3.0-3 build on it. Although
>> it seems to install fine, it doesnt show up anywhere in the menus or
>> in the filesystem that I can see. Does anyone have any knowledge on
>> Vista? Did I forget to do some magic incantation?
>> Regards
> Qgis-developer mailing list
