[Qgis-developer] Python console craches
Florian El Ahdab felahdab at gmail.com
Sun Oct 25 12:28:46 EDT 2009
Skipped content of type multipart/alternative-------------- next part --------------
Debug: empty extent... not rendering
Debug: fileVectorFilters, unknown driver: REC
Debug: fileVectorFilters, unknown driver: Memory
Python support ENABLED :-)
The program 'modpython' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
  (Details: serial 19205 error_code 8 request_code 42 minor_code 0)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
Locking assertion failure.  Backtrace:
#0 /usr/lib/libxcb-xlib.so.0 [0xb54af787]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_lock+0x2e) [0xb54af92e]
#2 /usr/lib/libX11.so.6 [0xb6398de9]
#3 /usr/lib/libXrender.so.1(XRenderFreePicture+0x41) [0xb64fcf81]
#4 /usr/lib/libQtGui.so.4 [0xb729939f]
#5 /usr/lib/libQtGui.so.4 [0xb7299e5d]
#6 /usr/lib/libQtGui.so.4(_ZN7QPixmap5derefEv+0x5d) [0xb728e6cd]
#7 /usr/lib/libQtGui.so.4(_ZN7QPixmapD2Ev+0x30) [0xb728eb30]
#8 /usr/lib/libQtGui.so.4 [0xb7293dda]
#9 /usr/lib/libQtGui.so.4 [0xb729444f]
#10 /usr/lib/libQtGui.so.4 [0xb7293a7a]
#11 /lib/i686/cmov/libc.so.6(exit+0x89) [0xb666fab9]
#12 /usr/lib/libgdk-x11-2.0.so.0 [0xb1299698]
#13 /usr/lib/libX11.so.6(_XError+0xd9) [0xb63917d9]
#14 /usr/lib/libX11.so.6 [0xb6399798]
#15 /usr/lib/libX11.so.6(_XReply+0x15a) [0xb6399b4a]
#16 /usr/lib/libX11.so.6(XTranslateCoordinates+0x81) [0xb638e991]
#17 /usr/lib/libQtGui.so.4(_ZNK7QWidget13mapFromGlobalERK6QPoint+0xe0) [0xb7252ce0]
#18 /usr/lib/libQtGui.so.4(_ZNK7QWidget13mapFromGlobalERK6QPoint+0x131) [0xb7252d31]
#19 /usr/lib/libQtGui.so.4(_ZNK7QWidget13mapFromGlobalERK6QPoint+0x131) [0xb7252d31]
