[Qgis-developer] How do you build the sample QGis application?
Marco Hugentobler
marco at hugis.net
Wed Oct 28 11:14:00 EDT 2009
Hi Henri
Hm, the link https://svn.osgeo.org/qgis/trunk/code_examples/ works for me.
Yes, you may use qmake. Just link your application with libqgis_core.dll and
maybe with libqgis_gui.dll
>CORE_EXPORT= GUI_EXPORT=
is for Linux where you don't need any dllexport macros
>CORE_EXPORT
> should be defined as __declspec(dllexport) and the same definition for
> GUI_EXPORT
Yes, on windows with msvc, you need to define those export macros.
Regards,
Marco
Am Mittwoch, 28. Oktober 2009 15.52:52 schrieb Henri De Feraudy:
> The QGis documentation for version 1.0.2 has a section that starts as
> following
> 16 Creating C++ Applications
> Not everyone wants a full blown GIS desktop application. Sometimes you want
> to just have a widget inside your application that displays a map while the
> main goal of the application lies elsewhere. Per- haps a database frontend
> with a map display? This Section provides two simple code examples by Tim
> Sutton. They are available in the qgis subversion repository together with
> more interesting tuto- rials. Check out the whole repository from:
> Unfortunately the link provided is not valid.
> I'm on WIndows XP.
> Now I started off hoping I could develop this application just like an
> ordinary Qt application, using QMake. Am I deluded? Do I have to learn
> CMake?
> All attempts I have tried have generated lots of compiler errors.
> Now I have peeked into a file CMakelists.tx that suggests that CORE_EXPORT
> GUI_EXPORT
> (but this is a guess)
> Are there any other defines?
> On Tim Sutton's blog someone suggested that there be a define
> QGISPLUGINDIR=$${QGISPLUGINDIR} CORE_EXPORT= GUI_EXPORT=
> This is contradictory with my __declspec(dllexport) (for the last two) and
> i cant find any occurence of QGISPLUGINDIR
> Thankyou
> Henri
> Qgis-developer mailing list
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
