[Qgis-developer] Which compiler should I use to build example
code?
Tim Sutton
lists at linfiniti.com
Sat Oct 31 16:18:24 EDT 2009
Hi
Which specific example are you trying to build? You should be able to build with msvc assuming you have LIB_DIR set to an osgeo4w installation the includes all the needed div libs.
Regards
Tim
Sent from my mobile phone.
-----Original Message-----
Date: Sat, 31 Oct 2009 12:58:36
To: <qgis-developer at lists.osgeo.org>
Subject: [Qgis-developer] Which compiler should I use to build example code?
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
