[Qgis-developer] Distance function between point and polygon/line
features
ahmed at elegantdesigns.ca
Fri Sep 4 08:23:37 EDT 2009
Motta,
Follow up questions:
1- can you create a new line layer that connects the existing point to
polygon/line layers?
2- can you specify the connection type: point to perpendicular to the edge
of line/polygon layer or point to vertex?
3- can it be done without PostGIS?
cheers,
dassouki
On Fri, 04 Sep 2009 08:56:48 -0300, "motta.luiz at gmail.com"
<motta.luiz at gmail.com> wrote:
> Francesco,
> You can see about geometry calculus from GEOS libray
> (http://trac.osgeo.org/geos/), have bindings for python.
> In Qgis see python plugins ftools, in ... /ftools/tools.
> francescoboccacci at libero.it escreveu:
>> Hi,
>> i'm a new user. I wat to ask if you if exist a method(function) in
python
>> to can calculate a distance between a poin feature and a polygon / line
>> features.
>> Thank you.
>> Francesco Boccacci
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
