[Qgis-developer] Accessing GPS devices platform independently
Marco Hugentobler
marco at hugis.net
Sun Sep 6 03:01:52 EDT 2009
Hi Bob
Wow, that sounds good! Let us know when the plugin is available. I could have
a look on the attribute problem (as long as the problem is in QGIS and not in
OGR library).
I agree with Tim that it would be good to have a class for live GPS access in
the core library. So probably we can port parts of the plugin to C++ later.
Regards,
Marco
Am Samstag, 5. September 2009 15.26:00 schrieb bob @ SHAW:
> Hi Marco:
> A few months ago I started work on a GPS plugin that
> would work on Windows since gpsd doesn't work there. I used Martin D's
> trackGPS plugin as a starting point. I've got it working over a serial
> port to the point where it is actively displaying the location on the
> map canvas. I got stuck at the point where I was going to save the
> track to a Shape file because I couldn't get the Shape writer to set
> up the attributes exactly the way that I had programmed it to (i.e.
> when a text attribute of a certain size was requested the attribute
> actually appeared in the file at some default size). This plugin is
> not as advanced as some that are under development, it only displays
> the position with various options and will save the track to a Shape
> file (when that part is finished) but it does work on Windows now. I
> plan to finish work on it this week and release it and I will be
> asking for help to get the Shape file attribute problem resolved. Any
> help that you or others could lend to this effort would be appreciated.
> Bob Bruce
> Sent from my iPhone
> On 2009-09-05, at 7:34, Marco Hugentobler <marco at hugis.net> wrote:
> > Hi devs
> > Is there a way to access the data from a GPS device (serial port or
> > USB port)
> > in a platform independent way? From what I have read, gpsd can be
> > used on
> > Linux but not on other platforms.
> > Is it necessary to directly parse the NMEA 0183 protocol on windows?
> > I see
> > there are some projects connecting gps devices and QGIS (QGIS track
> > GPS,
> > Quantum Navigator, QGIS mapper). Is there already some NMEA related
> > code?
> > Thanks for any suggestion,
> > Marco
> > Dr. Marco Hugentobler
> > HUGIS - GIS Programmierung und Beratung
> > Honrainweg 5
> > CH-8038 Zürich
> > marco at hugis.net
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
HUGIS - GIS Programmierung und Beratung Hugentobler
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
