[Qgis-developer] Re: [Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty +
GRASS does not work]
Jürgen E. Fischer
jef at norbit.de
Fri Sep 11 08:45:04 EDT 2009
On Fri, 11. Sep 2009 at 13:55:42 +0200, Agustin Lobo wrote:
> In grass
> r.in.gdal -o
> input=/media/Transcend/ANYELLA/catuav20090730/tif/SDIM0178.tif
> output=delmetif
That's the wrong direction. You need to access GRASS from GDAL not vice
versa.
gdalinfo $HOME/grass/spearfish60/PERMANENT/cellhd/elevation.10m
> $ sudo apt-get install qgis-plugin-grass
> Reading package lists... Done
> Building dependency tree Reading state information... Done
> The following extra packages will be installed:
> libgdal1-1.5.0 libgdal1-1.5.0-grass qgis-plugin-grass-common
> The following NEW packages will be installed:
> 0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
> Need to get 0B/9986kB of archives.
> After this operation, 19.4MB of additional disk space will be used.
> Do you want to continue [Y/n]? n
> Abort.
That's strange. Try
apt-cache rdepends libgdal1-1.5.0
to see what depends on libgdal1-1.5.0. There shouldn't be anything qgis or
grass related except for libgdal1-1.5.0-grass.
And try
apt-cache depends qgis-plugin-grass
to see what qgis-plugin-grass depends on. There should only be the dependency
to one of the libgdal1-*-grass packages - and that should be satisfiable by
installing libgdal1-1.6.0-grass.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
