[Qgis-developer] Re: [Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty +
GRASS does not work]
Jürgen E. Fischer
jef at norbit.de
Sat Sep 12 16:13:51 EDT 2009
Hi Agus,
On Sat, 12. Sep 2009 at 21:45:17 +0200, Agustin Lobo wrote:
>>> $ apt-cache rdepends libgdal1-1.5.0
>>> libgdal1-1.5.0
>>> Reverse Depends:
>>> grass
>> Which grass is that (apt-cache policy grass)?
>> That's what triggers the dependency to gdal 1.5. The ubuntugis jaunty grass
>> depends on libgdal1-1.6.0. So your grass must be from a different repository.
> $ apt-cache policy grass
> grass:
> Installed: 6.4.0~rc5-2~jaunty1
> Candidate: 6.4.0~rc5-2~jaunty1
> Version table:
> *** 6.4.0~rc5-2~jaunty1 0
> 500 http://ppa.launchpad.net jaunty/main Packages
> 100 /var/lib/dpkg/status
> is the grass 6.2.3-2.1 0 from archive.ubuntu.com causing problems?
Nope, I was probably wrong.
The package from archive is considered in apt-get rdepends, although it
wouldn't be installed. So that doesn't tell us which actually is the package
that triggers the dependency.
It might still be the or dependency in qgis-plugin-grass, if the dependencies
are processed in order and libgdal1-1.6.0-grass is not installed already. I
reversed the dependencies for 1.3.0.
BTW dpkg -l libgdal1-1.5.0-grass to check whether or not the package is
installed.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
