[Qgis-developer] Re: [Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty +
GRASS does not work]
Agustin Lobo
alobolistas at gmail.com
Sun Sep 13 04:11:46 EDT 2009
Jürgen E. Fischer wrote:
> Nope, I was probably wrong.
> The package from archive is considered in apt-get rdepends, although it
> wouldn't be installed. So that doesn't tell us which actually is the package
> that triggers the dependency.
> It might still be the or dependency in qgis-plugin-grass, if the dependencies
> are processed in order and libgdal1-1.6.0-grass is not installed already. I
> reversed the dependencies for 1.3.0.
> BTW dpkg -l libgdal1-1.5.0-grass to check whether or not the package is
> installed.
Done:
$ dpkg -l libgdal1-1.5.0-grass
Desired=Unknown/Install/Remove/Purge/Hold
Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err:
uppercase=bad)
||/ Name Version Description
pn libgdal1-1.5.0 <none> (no description available)
Anyway, everything is back to normality after the upgrade to qgis
1.2.0-2~jaunty1build1
and ligdal1-1.6.0-grass 1.6.0-3~jaunty1
Thanks,
Agus
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090913/9dabd2ec/alobolistas.vcf
