[Qgis-developer] dxf2shp plugin
Paolo Cavallini cavallini at faunalia.it
Wed Sep 23 11:31:15 EDT 2009
Paolo Cavallini ha scritto:
> Hi all.
> I'm testing the dxf2shp plugin, but I keep on getting:
> basic_string::substr
> Anyone has the same problem?
> Should I open a ticket?
> All the best.
My fault: if you do not specify an output shp, the plugin fails. If it specified, no problem.
See https://trac.osgeo.org/qgis/ticket/1308
It looks an easy fix (just checking wheter the output field is filled).
All the best, and sorry for the noise.
Paolo Cavallini: http://www.faunalia.it/pc
