[Qgis-developer] [Fwd: Re: [Qgis-user] GdalTools plugin
generatesan error on installation]
Tim Sutton
lists at linfiniti.com
Thu Sep 24 07:57:16 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Try to run ldd on your QGIS binary and see what gdal lib it is looking
for. Then check all the usual suspects:
- - is ccmake showing the correct gdal lib variable?
- - is gda 1.6 in your library search path
- - have you clean built since changing the gdal lib in cmake?
Regards
Tim
Paolo Cavallini wrote:
> Tim Sutton ha scritto:
>> Hi
>> Its probably the same issue of the stand alone installer (now fixed in build 1.3.0-3). Since we are linking to gdal 1.6 now, python must be set to look for gdal python pyd files in osgeo4w/apps/gdal1.6 instead of the default python libs path. No idea how to fix that in the osgeo4w dist, though no doubt Juergen will have an idea.
> Might be related to this: I just compiled QGIS on a Debian testing, with GDAL 1.6, correctly
> recognized; when I try to install a gdal plugin, it looks for gdal 1.5 and fails:
> libgdal1.5.0.so.1: cannot open shared object file: No such file or directory
> Any hint?
> All the best.
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkq7XpwACgkQqk07qZdiYjeTEACfaVO62Q+GX88u+BpSRBKUoUlk
2CkAoM3Z52MtTwFWc7dir2ifU97gJ5N8
=JF5U
-----END PGP SIGNATURE-----
