[Qgis-developer] Shaded Relief python plugin available pyqgis,org
Christy Nieman cnieman at dmsolutions.ca
Fri Sep 25 14:29:38 EDT 2009
I've noticed that there's no way to specify a scale factor between horizontal
and vertical units (e.g. if the DEM is in decimal degrees, and the vertical
units are meters).  I use the gdaldem tools to make hillshades right now,
and it allows you to specify such a scale factor (Feet:Latlong use
scale=370400, Meters:LatLong use scale=111120  - see
http://www.gdal.org/gdaldem.html).
Other than that, great plugin, love it!
View this message in context: http://n2.nabble.com/Shaded-Relief-python-plugin-available-pyqgis-org-tp3672021p3714068.html
Sent from the qgis-developer mailing list archive at Nabble.com.
