[SPAM] [Qgis-developer] cannot include port numbers in the url for python plugins?
Borys Jurgiel borysiasty at aster.pl
Wed Sep 30 04:07:06 EDT 2009
Dnia środa, 30 września 2009 o 01:05:52 Jeff Hamann napisał(a):
> It seems that we cannot include port numbers in the urls for qgis
> repositories, yes?
>    <pyqgis_plugin version='version 0.0.1' name='rufus'>
>      <homepage>http://www.forestinformatics.com:9182/qgis</homepage>
>      <download_url>http://www.forestinformatics.com:9182/qgis/
> rufus.zip</download_url>
>    </pyqgis_plugin>
> </plugins>
> while the html output displayed just fine, qgis would return an error.
> I've since moved the directory to a place that doesn't require the
> port number but want to keep the two httpd locations completely
> separate for now. is is possible to include the port number in the url?
Ok, everything installs well, but I assume it's only because you've masked it
with the instance not requiring port number.
It is likely that the installer ignores the port number - I'll check it
tonight and try to fix.
