[Qgis-developer] New labeling with print composer
Martin Dobias
wonder.sk at gmail.com
Sun Apr 4 05:29:27 EDT 2010
On Fri, Apr 2, 2010 at 10:24 AM, Tony Stewart <comp at mesajs.com> wrote:
> Question re the new labelling engine. It works well on the map canvas, but
> rendering in print composer has a number of problems:
> 1. Label placement is too low. For example, with line layers, if
> ‘above line’ is selected, the label appears almost over the line, and if
> ‘below line’ is selected, the label appears well below the line. With point
> layers where ‘around point’ is selected, then if the label is displayed
> below the point it is so far below that it can appear to be associated with
> another point when points are tightly clustered.
> 2. Spacing between characters in labels is all over the place.
> Characters can run into each other, other have unreasonably large
> separations.
Hi Tony
labeling plugin will need some tweaks to work properly in map
composer. Please file a bug for these issues, ideally with few
pictures illustrating the problems.
Regards
Martin
