AW: [Qgis-developer] IMPORTANT NOTICE to all python plugin authors
Düster Horst
Horst.Duester at bd.so.ch
Thu Apr 8 02:35:11 EDT 2010
Hi Borys
It's done for geoprocessing and wps.
Regards
Horst
Dr. Horst Düster
Stv. Amtschef / kantonaler GIS-Koordinator
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Mobil ++41(0)79 511 54 12
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Borys Jurgiel [mailto:borysiasty at aster.pl]
Gesendet am: Mittwoch, 7. April 2010 20:35
An: qgis-developer at lists.osgeo.org
Betreff: [Qgis-developer] IMPORTANT NOTICE to all python plugin authors
Dear Authors,
Due to removed qt3 support all plugin actions MUST send
a triggered() signal instead of the depreciated activated() one.
Please update your plugins by renaming the catched signal.
There is the list of affected plugins I can find below.
For more details, see http://trac.osgeo.org/qgis/ticket/1743
autosave/main.py:
QObject.connect(self.action,SIGNAL("activated()"),self.showSettings)
cadtools/tools/arcintersectiontool.py:
QObject.connect(self.act_intersect_arc, SIGNAL("activated()"),
self.showDialog)
QObject.connect(self.act_s2v, SIGNAL("activated()"), self.s2v)
cadtools/tools/lineintersectiontool.py:
QObject.connect(self.act_s2s, SIGNAL("activated()"), self.s2s)
QObject.connect(self.act_intersect_point, SIGNAL("activated()"),
self.intersect_point)
QObject.connect(self.act_intersect_line, SIGNAL("activated()"),
self.intersect_line)
cadtools/tools/orthogonaldigitizertool.py:
QObject.connect(self.act_ortho, SIGNAL("activated()"),
self.orthodigitize)
cadtools/tools/rectangularpointstool.py:
QObject.connect(self.act_rectpoints, SIGNAL("activated()"),
self.showDialog)
QObject.connect(self.act_selectlinesegment, SIGNAL("activated()"),
self.selectlinesegment)
cadtools/tools/orthogonaltraversetool.py:
QObject.connect(self.act_showDialog, SIGNAL("activated()"),
self.showDialog)
QObject.connect(self.act_select2vertex, SIGNAL("activated()"),
self.select2vertex)
cadtools/tools/orthoelementsonsegmenttool.py:
QObject.connect(self.act_ortholineandpoint, SIGNAL("activated()"),
self.ortholineandpoint)
QObject.connect(self.act_selectvertexandline, SIGNAL("activated()"),
self.selectvertexandline)
cartogram/Cartogram.py: QObject.connect(self.action,
SIGNAL("activated()"), self.run)
cartogram/Cartogram.py: QObject.connect(self.helpaction,
SIGNAL("activated()"), self.helprun)
cataloginpecreate/cataloginpe_qg.py:
QtCore.QObject.connect(self.action, QtCore.SIGNAL("activated()"),
self.run)
clickfu/clickFuUtils.py:
QObject.connect(self,SIGNAL("activated()"),self.doit)
composer_plugin/composerplugin.py: QObject.connect(self.action,
contour/contour.py: QObject.connect(self.action,
dpsimplify/dpsimplify.py: QObject.connect( self.actionRun, SIGNAL(
"activated()" ), self.run )
dpsimplify/dpsimplify.py: QObject.connect( self.actionAbout, SIGNAL(
"activated()" ), self.about )
dumpfield/dumpfield.py: QObject.connect(self.action,
SIGNAL("activated()"), self.dumpfield)
SIGNAL("activated()"), self.loadtofield)
elevation/Elevation.py: QObject.connect(self.obtainAction,
SIGNAL("activated()"), self.obtain)
elevation/Elevation.py: QObject.connect(self.aboutAction,
SIGNAL("activated()"), self.about)
findbyattr/Findbyattr.py: QObject.connect(self.action,
GdalTools/tools/doClipper.py: self.connect(self.clipper,
SIGNAL("deactivated()"), self.pauseClipping)
GdalTools/tools/doClipper.py: self.emit(SIGNAL("deactivated()"))
GeoCoding/GeoCoding.py: QObject.connect(self.action,
SIGNAL("activated()"), self.geocode)
GeoCoding/GeoCoding.py: QObject.connect(self.configAction,
SIGNAL("activated()"), self.config)
GeoCoding/GeoCoding.py: QObject.connect(self.reverseAction,
SIGNAL("activated()"), self.reverse)
GeoCoding/GeoCoding.py: QObject.connect(self.aboutAction,
geofeeds/FeedPlugin.py: QObject.connect(self.action,
geoprocessing/geoprocessing.py:
QObject.connect(self.actionGeoprocessing, SIGNAL("activated()"),
self.run_geoprocessing_ctrl)
ghydraulic/ghydraulicplugin.py: QObject.connect(self.action,
HomeRange_plugin/HRplugin_main.py: QObject.connect(self.action,
SIGNAL("activated()"), lambda method="all": self.showInterface(method))
HomeRange_plugin/HRplugin_main.py: QObject.connect(getattr(self,
"action" + k), SIGNAL("activated()"), lambda method=k:
image_clipper/imageclipper.py: QObject.connect(self.action,
SIGNAL("activated()"), self.dlgImageClipper)
image_cutter/image_cutter.py: QObject.connect(self.action,
SIGNAL("activated()"), self.dlgImageCutter)
image_cutter/image_cutter.py: QObject.connect(self.helpAction,
SIGNAL("activated()"), self.helpWindow)
imagemap_plugin/imagemapplugin.py: QObject.connect(self.action,
imgboundary/imgboundary_qg.py: QObject.connect(self.action,
infotool/info.py: QObject.connect(self.action, SIGNAL("activated()"),
self.inforun)
infotool/info.py: QObject.connect(self.helpaction,
infotool/info.py: QObject.connect(self.confaction,
SIGNAL("activated()"), self.confrun)
joinlines/joinlines.py: QObject.connect(self.action,
manageR/pluginManager.py: SIGNAL("activated()"),
self.callerlist[-1])
manageR/plugin.py: QObject.connect(self.action,
MapSheetAutoGeoRef/mapsheetgeoref.py:
QObject.connect(self.action, SIGNAL("activated()"), self.run)
mergeshapes/mergeshapes.py: QObject.connect( self.actionRun, SIGNAL(
mergeshapes/mergeshapes.py: QObject.connect( self.actionAbout,
SIGNAL( "activated()" ), self.about )
metaedit/metaeditTool.py:
QObject.connect(self.comboBoxFileLayer,SIGNAL("activated(int)"),self.lay
er_selected)
metaedit/metaedit.py: QObject.connect(self.action,
mirrormap/mirrormap.py: QObject.connect(self.helpaction,
mirrormap/mirrormap.py: QObject.connect(self.mirrormapaction,
SIGNAL("activated()"), self.mirrormaprun)
mirrormap/mirrormap.py: QObject.connect(self.addrasteraction,
SIGNAL("activated()"), self.addRasterLayer)
mirrormap/mirrormap.py: QObject.connect(self.addograction,
SIGNAL("activated()"), self.addVectorLayer)
mirrormap/mirrormap.py: QObject.connect(self.adddbaction,
mirrormap/mirrormap.py: QObject.connect(self.addwmsaction,
multiqml/plugin.py: QObject.connect( self.actionRun, SIGNAL(
multiqml/plugin.py: QObject.connect( self.actionAbout, SIGNAL(
numericalVertexEdit/numericalvertexedit.py:
OGR2Layers/ogr2Layers.py: QObject.connect(self.action,
openaddresses_converter/openaddressesconverter.py:
osmpoly_export/polygenerator.py: QObject.connect(self.action,
photo2shape/photo2shape.py: QObject.connect( self.actionRun, SIGNAL(
photo2shape/photo2shape.py: QObject.connect( self.actionAbout,
PostGisTools/PostGisTools.py:
QObject.connect(self.toolfileAction,
SIGNAL("activated()"),self.setToolsFile )
PostGisTools/PostGisTools.py: QObject.connect(self.aboutAction,
SIGNAL("activated()"),self.about )
QObject.connect(self.actionlist[-1], SIGNAL("activated()"),
postgps/postgps.py: QObject.connect(self.action1,
qgisrest/qgisrest.py: QObject.connect(self.action,
qgisrest/qgisrest.py: QObject.connect(self.helpaction,
qgsAffine/qgsAffine.py: QObject.connect(self.action,
qgsAzimuth/qgsAzimuth.py: QObject.connect(self.action,
quantumnik/quantumnik.py: QObject.connect(self.action,
SIGNAL("activated()"), self.toggle)
quantumnik/quantumnik.py: QObject.connect(self.action4,
SIGNAL("activated()"), self.view_xml)
quantumnik/quantumnik.py: QObject.connect(self.action3,
SIGNAL("activated()"), self.save_xml)
quantumnik/quantumnik.py: QObject.connect(self.action5,
SIGNAL("activated()"), self.load_xml)
quantumnik/quantumnik.py: QObject.connect(self.action6,
SIGNAL("activated()"), self.load_mml)
quantumnik/quantumnik.py: QObject.connect(self.action7,
quantumnik/quantumnik.py: QObject.connect(self.helpaction,
quicksaveqml/quicksaveqml.py: QObject.connect(self.action,
rastercalc/rasterlang.py: QObject.connect( self.action, SIGNAL(
rastercalc/rastercalcdialog.py: QObject.connect( self.cmbPresets,
SIGNAL( "activated( QString )" ), self.insertPreset )
rastercalc/rastercalc.py: QObject.connect( self.actionRun, SIGNAL(
rastercalc/rastercalc.py: QObject.connect( self.actionAbout, SIGNAL(
rasterCatalog/rastercatalogplugin.py: QObject.connect(self.action,
rasterinfo/rasterfileinfo.py: QObject.connect(self.action,
rasterinfo/rasterfileinfo.py: QObject.connect(self.helpaction,
rasterlang/main.py:
QObject.connect(self.action,SIGNAL("activated()"),self.run)
rasterlang2/main.py:
refmap/refmap.py: QObject.connect(self.helpaction,
refmap/refmap.py: QObject.connect(self.refmapaction,
SIGNAL("activated()"), self.refmaprun)
rgb/Rgb.py: QObject.connect(self.action, SIGNAL("activated()"),
self.run)
selectplus/selectionTools.py: QObject.connect(self,
SIGNAL("activated()"), self.doit)
shapefile_splitter/shapefile_splitter.py:
testplugin/plugin.py: QObject.connect(self.action,
testplugingl/plugin.py: QObject.connect(self.action,
threading_demo/threading_demo.py: QObject.connect(self.action,
QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
VectorFieldRenderer/VectorFieldRendererController.py:
QObject.connect(action1,SIGNAL("activated()"), self.autoRescale )
QObject.connect(action2,SIGNAL("activated()"), self.enlarge )
QObject.connect(action3,SIGNAL("activated()"), self.shrink )
QObject.connect(action4,SIGNAL("activated()"), self.setScaleBoxOptions )
QObject.connect(action5,SIGNAL("activated()"), self.showHelp )
wps/qgswps.py: QObject.connect(self.action, SIGNAL("activated()"),
self.run)
ziplayers/ziplayers_qg.py: QtCore.QObject.connect(self.action,
QtCore.SIGNAL("activated()"), self.run)
zoom_to_point/zoomtopoint.py: QObject.connect(self.action,
zoom_to_point_BB/zoomtopoint.py: QObject.connect(self.action,
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100408/42a70bf4/attachment-0001.html
