[Qgis-developer] qgis-1.5.0_coding-compilation_guide_en.pdf
Benoit de Cabissole
benoit at exigesa.com
Sun Aug 22 10:02:52 EDT 2010
And while I'm at it, on page 31, the 'else:' statement in the top code block
is wrongly indented!
Sorry to be a pain,
Benoit
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org]On Behalf Of Benoit de
> Cabissole
> Sent: Sunday, 22 August 2010 15:46
> To: qgis-developer at lists.osgeo.org
> Subject: [Qgis-developer] qgis-1.5.0_coding-compilation_guide_en.pdf
> Hello Manual Team,
> With reference to the subject and to recent discussions in this forum
> regarding plugins coding standard:
> - on page 29, the __init__.py example (at the bottom of the page) could be
> rewritten as:
> # -*- coding: utf-8 -*-
> def name():
> return "FOSS4G example"
> def description():
> return "A simple example plugin to load shapefiles"
> def version():
> return "0.1"
> def qgisMinimumVersion():
> return "1.0"
> def authorName():
> return "John Developer"
> def classFactory(iface):
> from foss4gplugin import FOSS4GPlugin
> return FOSS4GPlugin(iface)
> Where the import line is put inside the classFactory() function and not in
> the first line of the file.
> Just trying my two bits for consistency...
> Cheers and keep the good work,
> Benoit
> Qgis-developer mailing list
