[Qgis-developer] qgis-1.5.0_coding-compilation_guide_en.pdf
Otto Dassau
otto.dassau at gmx.de
Mon Aug 23 04:00:07 EDT 2010
Hi Benoit,
thanks for your note. I committed your change. If you have more fixes or
ideas to improve the manual, please write to the qgis-community team list
at qgis-community-team at lists.osgeo.org. That is the place we usually discuss
and improve the documentation and where most documenters are subscribed.
Regards,
otto
Am Sun, 22 Aug 2010 15:45:53 +0200
schrieb "Benoit de Cabissole" <benoit at exigesa.com>:
> Hello Manual Team,
> With reference to the subject and to recent discussions in this forum
> regarding plugins coding standard:
> - on page 29, the __init__.py example (at the bottom of the page) could be
> rewritten as:
> # -*- coding: utf-8 -*-
> def name():
> return "FOSS4G example"
> def description():
> return "A simple example plugin to load shapefiles"
> def version():
> return "0.1"
> def qgisMinimumVersion():
> return "1.0"
> def authorName():
> return "John Developer"
> def classFactory(iface):
> from foss4gplugin import FOSS4GPlugin
> return FOSS4GPlugin(iface)
> Where the import line is put inside the classFactory() function and not in
> the first line of the file.
> Just trying my two bits for consistency...
> Cheers and keep the good work,
> Benoit
> Qgis-developer mailing list
