[Qgis-developer] Integration of QGIS mapserver to svn?
Andreas Neumann
a.neumann at carto.net
Mon Aug 23 17:04:06 EDT 2010
On Mon, Aug 23, 2010 at 9:08 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
>> +0 for QGIS Server and +1 for QGIS Mobile.
>> While I like "QGIS Server" as a name, there may be different "QGIS Servers"
>> in the future? Maybe a QGIS WFS server? Or a QGIS WPS or geoprocessing
>> server? Or a QGIS printserver?
> Wouldnt they all be the same server just with different service type
> requests? Would be nicer than needing to deploy 4 server binaries....
indeed it would be nicer to have just one binary handling different
services. If this doesn't make the thing bloated and if it is
technically feasible.
>> I would see "QGIS Server" as a family of upcoming potential servers and
>> "QGIS WMS server" for the great work that Marco just did. I also still like
>> "QGIS Mapserver" or "QGIS Webmap Server" which actually describes what it is
>> - serving styled maps for web-connected devices and applications.
> I love how we discuss names more than the actual thing Marco made :-)
> For those who are interested, here is a quick guide to getting
> started:
> http://linfiniti.com/2010/08/qgis-mapserver-a-wms-server-for-the-masses/
> (docs team you are welcome to reappropriate that for the next manual
> if it is useful to you...)
thanks for this first documentation.
Here are a few notes you could add to your blog:
* QGIS Mapserver (or however it will be called) implements WMS 1.3 only
(not WMS 1.1.1)
* GetFeatureInfo should support: text, html, xml
* GetFeatureInfo honors some of the attribute settings of a QGIS layer:
hidden attributes are suppressed, column aliases are used if present.
* When doing the GetCapabilities, the answer can be very slow and big,
because for every layer, QGIS will return all available CRS. You can
limit this list by using adding the following XML elements to the
properties section:
<properties>
<WMSEpsgList type="QStringList">
<value>21781</value>
<value>4326</value>
</WMSEpsgList>
</properties>
QGIS will not remove these settings from the .qgs file after saving it
from the desktop version, but currently there is no GUI to do the WMS
settings.
* By default, QGIS Mapserver will advertise the maximum extent of all
involved layers. This can be overridden by the following setting, again
in the <properties> section of a .qgs file; replace with your own
min/max settings:
<properties>
<WMSExtent type="QStringList">
<value>692000</value>
<value>241500</value>
<value>700100</value>
<value>249000</value>
</WMSExtent>
</properties>
* GetLegendGraphics should work, e.g.
http://yourserver/cgi/qgis_mapserv.fcgi?map=/home/qgisprojects/myproject.qgs&SERVICE=WMS&REQUEST=GetLegendGraphics&FORMAT=image/png&LAYERS=hydrology&WIDTH=400
* QGIS Mapserver can handle multiple project files with one fcgi binary.
On a first request of a newly started Apache server, the request will be
slower, because the .qgs file has to be parsed, later requests are fast,
because there is a cache for more .qgs files. You can use the
"map=/home/path/to/your/project.qgs" parameter to specify which project
you want to access
It would be nice if we could expose some of the "hidden" WMS properties
in a GUI, somewhere in the QGIS project properties. Maybe a
Server-Settings tab.
Andreas
