[Qgis-developer] QGIS build with GDAL 1.7.x - Ubuntu
Noli Sicad
nsicad at gmail.com
Sat Aug 28 22:00:15 EDT 2010
Hi Juergen,
I still have problem opening spatialite database / files in trunk
version - Quantum GIS - 1.6.0-Trunk 'Trunk' (14162M).
I am using Ubuntu 10.04. I think there is no problem with ubuntu 9.10,
as some of the users are indicated before.
Anybody using Ubuntu 10.04 and can open spatialite database and what
versions of QGIS, spatialite, ogr2org, etc.
The mac os x QGIS-dev has almost same libraries used in QGIS 1.5.0.2
lucid except the Qt 4.6.3 instead of Qt4.6.2.
Here's log files of various versions of the libraries used in
noli at noli-laptop:~$ cat /etc/issue
Ubuntu 10.04 LTS \n \l
noli at noli-laptop:~$ ogr2org -version
No command 'ogr2org' found, did you mean:
Command 'ogr2ogr' from package 'gdal-bin' (universe)
ogr2org: command not found
noli at noli-laptop:~$ ogr2org --version
noli at noli-laptop:~$ org2org --version
org2org: command not found
noli at noli-laptop:~$ ogr2ogr --version
GDAL 1.7.2, released 2010/04/23
noli at noli-laptop:~$ spatialite --version
SpatiaLite version ..: 2.4.0 Supported Extensions:
- 'VirtualShape' [direct Shapefile access]
- 'VirtualDbf' [direct DBF access]
- 'VirtualText' [direct CSV/TXT access]
- 'VirtualNetwork' [Dijkstra shortest path]
- 'RTree' [Spatial Index - R*Tree]
- 'MbrCache' [Spatial Index - MBR cache]
- 'VirtualFDO' [FDO-OGR interoperability]
- 'SpatiaLite' [Spatial SQL - OGC]
PROJ.4 version ......: Rel. 4.7.1, 23 September 2009
GEOS version ........: 3.2.2-CAPI-1.6.2
3.6.22
noli at noli-laptop:~$ qgis --version
qgis: unrecognized option '--version'
Quantum GIS (QGIS) is a viewer for spatial data sets, including
raster and vector data.
Usage: qgis [options] [FILES]
options:
[--snapshot filename] emit snapshot of loaded datasets to given file
[--width width] width of snapshot to emit
[--height height] height of snapshot to emit
[--lang language] use language for interface text
[--project projectfile] load the given QGIS project
[--extent xmin,ymin,xmax,ymax] set initial map extent
[--nologo] hide splash screen
[--noplugins] don't restore plugins on startup
[--optionspath path] use the given QSettings path
[--configpath path] use the given path for all user configuration
[--help] this text
FILES:
Files specified on the command line can include rasters,
vectors, and QGIS project files (.qgs):
1. Rasters - Supported formats include GeoTiff, DEM
and others supported by GDAL
2. Vectors - Supported formats include ESRI Shapefiles
and others supported by OGR and PostgreSQL layers using
the PostGIS extension
options:
[--help] this text
FILES:
noli at noli-laptop:~$ clear
3.6.22
Thanks.
Noli
