[Qgis-developer] Memory data provider persistence
Chris Crook
ccrook at linz.govt.nz
Mon Dec 6 17:18:34 EST 2010
Further to this .. I've raised a ticket #3297 with a patch to add a projectSaved() signal matching the projectRead().
http://trac.osgeo.org/qgis/ticket/3297
This should make building a memory provider saving plugin trivial.
Could this be committed if it looks Ok.
Thanks
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
