[Qgis-developer] Edit UI doesn't load the field's value
Giuseppe Sucameli
sucameli at faunalia.it
Tue Dec 7 13:11:52 EST 2010
Hi Bernhard,
On Tue, Dec 7, 2010 at 7:56 AM, Bernhard Ströbl <Bernhard.Stroebl at jena.de>wrote:
> I can confirm this behaviour QGIS 1.5/WinXP, data from PostGIS database.
Did you file a ticket yet?
My workaround is to have e.g. the QComboBox filled with values and
> _additionally_ have a QTextLine named the same as the field in my layer
> table holding the feature's current value. The QTextLine is not visible to
> the user but gets changed if the user changes the choice in the QComboBox by
> Qt'S Signal/Slot mechanism.
You're right, I understand that a developer can use the initFunction and
editForm
from API to bypass the issue, but how can users do the same?
Thinking like an user, if I sets the edit UI from the layer property dialog,
the obvious
behaviour is that each combo must be populated and it must show the right
value
as the lineedit does.
If the combobox (but also the spinbox) doesn't show the right value, then
it's a bug.
Maybe did I start a thread on the wrong ML? Maybe I did.
But I hope we'll fix it quickly :)
Let me know if there's a opened ticket, otherwise I file a new one.
Thanks, and best regard.
all the best
> Bernhard
> Giuseppe Sucameli schrieb:
>> Hi all,
>> it seems there is a problem with Edit UI dialog.
>> I have an .UI which contains a combobox and a spinbox.
>> When I edit a row using the Edit UI dialog, the combobox PROVINCIA loads
>> all the values of the PROVINCIA field, but doesn't select the current row
>> value.
>> The spinbox does the same, it doesn't load the current value.
>> If I use lineedits instead, it works and loads the fields' value.
>> Loading only doesn't work, because if I change the value and and press OK
>> the dialog stores the new value back into the field.
>> Does anybody confirm??
>> Cheers.
>> Giuseppe Sucameli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> ________ Information from NOD32 ________
>> This message was checked by NOD32 Antivirus System for Linux Mail Server.
>> http://www.nod32.com
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101207/97df058f/attachment.html
