Re: [Qgis-developer] Spatialite ’select’ statement as vector layer in QGIS
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Thu Dec 9 05:40:21 EST 2010
Sorry, forgot to add this:
I will add a small help page explaining the functionality later.
Probably tomorrow.
Cheers
On Thu, Dec 9, 2010 at 10:38 AM, Ricardo Filipe Soares Garcia da
<ricardo.garcia.silva at gmail.com> wrote:
> Hello
> I have uploaded my plugin to the contributed repository. I marked it
> as experimental. It is called 'Custom DB query'. I did a bit of
> cleaning up and even managed to get the 'normal query' feature to
> work.
> So, by now you can:
> - run an SQL query and choose to view the result in the map canvas or
> in a table format. This is only working for spatialite layers. Postgis
> will come later.
> Beware that I am not parsing the SQL in any way! So please be careful
> about what SQL queries you write, that can potentially damage your
> database. If you stick to SELECT statements it is OK.
> I didn't mean to bring one more spatial db plugin to the table, when
> there are currently so many ;)
> I will retire this one in due time.
> ___________________________ ___ __
> Ricardo Garcia Silva
