[Qgis-developer] Analysis/Point sampling tool: join original table
Agustin Lobo alobolistas at gmail.com
Sat Dec 11 05:42:42 EST 2010
(Sorry for resending: the original message had a wrong subject)
2010/12/10 Agustin Lobo <alobolistas at gmail.com>:
> Hi,
> Plugin Analysis/Point sampling tool should merge the table of
> the points layer with the one of the data extracted from the other layers (at least optionally).
> Otherwise the user must define
> an ID for the new layer, (eventually also for the one with the sampling points)
> and then use vector/Join Attributes.
> Is the trac for plugins up?
> Agus
