[Qgis-developer] add postgis raster
Maurício de Paulo
mauricio.dev at gmail.com
Mon Dec 13 13:27:52 EST 2010
Indeed, a bug on table listing error message. I'm going to update the
version on the repo now.
Best regards,
Mauricio de Paulo
2010/12/13 Maurício de Paulo <mauricio.dev at gmail.com>
> Seems like a gui bug on the plugin. I'm going to review it. But as it says,
> it's failing to connect to the data. Are you using gdal 1.7 or higher?
> Could you tell us the test evironment?
> Thanks for the information.
> Mauricio de Paulo
> On Mon, Dec 13, 2010 at 4:09 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
>> Hi all.
>> I'm getting repeated errors while loading PostGIS rasters in QGIS.
>> Any idea?
>> All the best.
>> Errore durante l'esecuzione di codice Python:
>> Traceback (most recent call last):
>> File "/home/paolo/.qgis/python/plugins/wktraster/wktRaster.py", line 115,
>> in listTables
>> QMessageBox.warning(self.dlg,"Connection failed to "+conn)
>> TypeError: arguments did not match any overloaded call:
>> QMessageBox.warning(QWidget, QString, QString,
>> QMessageBox.StandardButtons
>> buttons=QMessageBox.Ok, QMessageBox.StandardButton
>> defaultButton=QMessageBox.NoButton): not enough arguments
>> QMessageBox.warning(QWidget, QString, QString, int, int, int button2=0):
>> not enough
>> arguments
>> QMessageBox.warning(QWidget, QString, QString, QString, QString
>> button1Text=QString(), QString button2Text=QString(), int
>> defaultButtonNumber=0, int
>> escapeButtonNumber=-1): not enough arguments
>> Versione Python:
>> 2.6.6 (r266:84292, Dec 12 2010, 15:29:35)
>> [GCC 4.4.5]
>> Versione di QGIS:
>> 1.7.0-Trunk Trunk, 14778M
>> Percorso Python: ['/home/paolo/.qgis/python/plugins/GeoCoding',
>> '/home/paolo/.qgis/python/plugins/cswclient',
>> '/home/paolo/.qgis/python/plugins/elevation',
>> '/home/paolo/.qgis/python/plugins/GeoCoding', '/usr/share/qgis/python',
>> '/home/paolo/.qgis/python', '/home/paolo/.qgis/python/plugins',
>> '/usr/share/qgis/python/plugins', '/usr/lib/python2.6',
>> '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
>> '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
>> '/usr/local/lib/python2.6/dist-packages',
>> '/usr/lib/python2.6/dist-packages',
>> '/usr/lib/python2.6/dist-packages/PIL',
>> '/usr/lib/python2.6/dist-packages/gst-0.10',
>> '/usr/lib/pymodules/python2.6', '/usr/lib/pymodules/python2.6/gtk-2.0',
>> '/home/paolo/.qgis/python/plugins/ziplayers/logic',
>> '/home/paolo/.qgis/python/plugins/ziplayers/gui',
>> '/home/paolo/.qgis/python/plugins/cadtools/tools',
>> '~/.qgis/python', '/home/paolo/.qgis/python/plugins/imgshowhide/logic',
>> '/home/paolo/.qgis/python/plugins/imgshowhide/gui',
>> '/usr/share/qgis/python/plugins/fTools/tools', '/usr/share/qgis/python/',
>> '/usr/share/qgis/python/']
>> Paolo Cavallini: http://www.faunalia.it/pc
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Mauricio de Paulo
> Engenheiro Cartografo
> MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
Mauricio de Paulo
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101213/87725767/attachment.html
