[Qgis-developer] Remove geoprocessing plugin?
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Dec 13 16:07:09 EST 2010
Hi Martin
> IIRC annotations are always bound to a particular position on map, so
> they're a bit different than the copyright label that is always in the
> corner...
The screen position is kept constant if you go to the item properties dialog
(double click) and uncheck 'Fixed map position'.
Regards,
Marco
Am Montag, 13. Dezember 2010, um 21.05:29 schrieb Martin Dobias:
> Hi Tim
> On Mon, Dec 13, 2010 at 10:06 AM, Tim Sutton <lists at linfiniti.com> wrote:
> > +1
> > And other candidates to recieve the axe:
> >  - quickprint
> I would vote to remove it once we have some print composer templates:
> so that people can print / export to pdf with no effort to lay out the
> items.
> >  - copyright (you can just add an annotation)
> corner...
> Cheers
> Martin
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
