[Qgis-developer] Remove geoprocessing plugin?
Paolo Cavallini cavallini at faunalia.it
Tue Dec 14 02:16:13 EST 2010
Il 13/12/2010 21:05, Martin Dobias ha scritto:
> I would vote to remove it once we have some print composer templates:
> so that people can print / export to pdf with no effort to lay out the
> items.
there is a nice plugin: EasyPrint, that could replace QuickPrint, after some tuning
(e.g. replacing the heading). I suggest to add it to trunk.
>>  - copyright (you can just add an annotation)
> IIRC annotations are always bound to a particular position on map, so
> they're a bit different than the copyright label that is always in the
> corner...
I remember there was a copyright python plugin; I think this could replace the C++
implementation, being more flexible.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
