[Qgis-developer] Error for postgres's provider when
table(statement SELECT ) is outside public's schema
Noli Sicad
nsicad at gmail.com
Wed Dec 15 21:58:28 EST 2010
Hi Ricardo,
In postgis error.
The plugin has the same problem when you checkbox is on for "save new
layer to database".
However, if I unchecked it this is the error.
Unable to execute the query.
The error message from the database was:
ERROR: column "A" does not exist
LINE 1: ...ect * from (Select * from stands where veg_type = "A") as "s...
SQL: select * from (Select * from stands where veg_type = "A") as
"subQuery_0" limit 1
Noli
On 12/16/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Ricardo,
> Spatialite database bug.
> The bug is in checkbox (on./check) "save new layer to database".
> When I unchecked (off), it works but the resulting map in TOC is "sql
> layer".
> The postgis bug, I don't know the reason since it does not work as
> well in the other postgis plugin (i.e PGManager).
> Noli
> On 12/16/10, Ricardo Filipe Soares Garcia da
> <ricardo.garcia.silva at gmail.com> wrote:
>> Hi Noli
>> I can't seem to reproduce any of your errors with my sample data.
>> Can you give me some more information? What queries are you trying?
>> Is it possible for you to send me some testing data?
>> On Thu, Dec 16, 2010 at 1:47 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi Ricardo,
>>> I got another error in 0.4, this time in PostGI. This is simple query.
>>> An error has occured while executing Python code:
>>> Traceback (most recent call last):
>>> File
>>> "/home/noli/.qgis/python/plugins/customdbquery/CustomDBQueryDialog.py",
>>> line 175, in parse_SQL_text
>>> self.execute_query(selectQuery)
>>> File
>>> line 187, in execute_query
>>> self.run_normal_query(createTableQuery, connection)
>>> File
>>> line 238, in run_normal_query
>>> cursor.execute(query)
>>> ProgrammingError: column "A" does not exist
>>> LINE 1: ...ne.Veg_TYPE_A AS (Select * from stands where veg_type = "A")
>>> Python version:
>>> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
>>> [GCC 4.4.3]
>>> QGIS version:
>>> 1.7.0-Trunk Trunk, 14914M
>>> The previous error was in Spatialite.
>>> Thanks.
>>> Noli
>> ___________________________ ___ __
>> Ricardo Garcia Silva
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
