[Qgis-developer] Error for postgres's provider when
table(statement SELECT ) is outside public's schema
Noli Sicad
nsicad at gmail.com
Wed Dec 15 23:33:59 EST 2010
Hi Ricardo,
To replicate my error in Spatialite database.
Please download the test-2.3.zip from
http://www.gaia-gis.it/spatialite-2.3.0/resources.html
Do the following query on the Regions table:
Select * from Regions where NAME = "VENETO"
You will see the errors.
Have a look at as well the "sql layer" attribute table.
Using Ubuntu 10.04, GGIS 1.7 trunk r14914M.
Thanks.
Noli
Thanks.
Noli
On 12/16/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Ricardo,
> In postgis error.
> The plugin has the same problem when you checkbox is on for "save new
> layer to database".
> However, if I unchecked it this is the error.
> Unable to execute the query.
> The error message from the database was:
> ERROR: column "A" does not exist
> LINE 1: ...ect * from (Select * from stands where veg_type = "A") as "s...
> SQL: select * from (Select * from stands where veg_type = "A") as
> "subQuery_0" limit 1
> Noli
>> Hi Ricardo,
>> Spatialite database bug.
>> The bug is in checkbox (on./check) "save new layer to database".
>> When I unchecked (off), it works but the resulting map in TOC is "sql
>> layer".
>> The postgis bug, I don't know the reason since it does not work as
>> well in the other postgis plugin (i.e PGManager).
>> Noli
>> On 12/16/10, Ricardo Filipe Soares Garcia da
>> <ricardo.garcia.silva at gmail.com> wrote:
>>> Hi Noli
>>> I can't seem to reproduce any of your errors with my sample data.
>>> Can you give me some more information? What queries are you trying?
>>> Is it possible for you to send me some testing data?
>>> On Thu, Dec 16, 2010 at 1:47 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>> Hi Ricardo,
>>>> I got another error in 0.4, this time in PostGI. This is simple query.
>>>> An error has occured while executing Python code:
>>>> Traceback (most recent call last):
>>>> File
>>>> "/home/noli/.qgis/python/plugins/customdbquery/CustomDBQueryDialog.py",
>>>> line 175, in parse_SQL_text
>>>> self.execute_query(selectQuery)
>>>> File
>>>> line 187, in execute_query
>>>> self.run_normal_query(createTableQuery, connection)
>>>> File
>>>> line 238, in run_normal_query
>>>> cursor.execute(query)
>>>> ProgrammingError: column "A" does not exist
>>>> LINE 1: ...ne.Veg_TYPE_A AS (Select * from stands where veg_type = "A")
>>>> Python version:
>>>> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
>>>> [GCC 4.4.3]
>>>> QGIS version:
>>>> 1.7.0-Trunk Trunk, 14914M
>>>> The previous error was in Spatialite.
>>>> Thanks.
>>>> Noli
>>> ___________________________ ___ __
>>> Ricardo Garcia Silva
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
